VEBill,
I agree that price is the perfect surrogate for total system efficiency. As GregLocock pointed out, the problem comes in when the government distorts markets or when you use national averages for local results. Let's pick one market--Anaheim, CA.
[ul]
[li]Electric Vehicle--Chevy Volt (first generation, all electric, range 25-50 miles)[/li]
[li]Electric Provider--So California Edison[/li]
[li]Electric rate--Three tiers, first tier (0-430 kWh/mo) $0.17/kWh, second tier (431-1720 kWh/mo) $0.25/kWh, third tier (above 1721 kWh/mo) $0.35/kWh. Assume that all of the first tier is taken up by normal household loads, and that the EV doesn't push the household onto the third tier (which it very well may) so the rate is $0.25/kWh[/li]
[li]EV "fuel efficiency"--2 mi/kWh or 0.5 kWh/mi[/li]
[li]
EV fuel cost--$0.125/mi[/li]
[li]Gasoline powered vehicle--Assume a Toyota Camry (29 mpg in city driving, range 450 miles)[/li]
[li]Gross Cost of gasoline today in Anaheim--$3.33/gallon ($0.115/mi)[/li]
[li]Fuel tax in California--$0.583/gallon[/li]
[li]
Cost of fuel without taxes--$2.74/gallon ($0.094/mi)[/li]
[/ul]
So without the national averaging or the EPA's outrageous practice of comparing post-Carnot electricity to pre-Carnot gasoline, two similar vehicles in similar service the gasoline is slightly cheaper to operate with all-in taxes and significantly cheaper with the taxes removed. Other vehicle pairings would narrow or widen the gap, different locations will change the pricing, but none of this will change the outcome noticeably--anyone who purchases an EV because of the fuel-cost savings will be disappointed. There are certainly many motivations for purchasing an EV, but the games people play with fuel efficiency are unconscionable and should not be a reason for purchasing an EV.
[bold]David Simpson, PE[/bold]
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
