1
- #1
I haven't managed to find a lot about this online - there seems to be plenty of information regarding "setting up" a particular vehicle for a specific purpose (street, track, drifting, etc.) but these discussions are mostly limited to adjusting the static cambers of a particular car.
What I'm looking for is the more general case: in an arbitrary vehicle where the static cambers and camber gains of the front and rear suspensions can be arbitrarily chosen, what are the factors affecting their selection, but in particular, what affects the choice of variation between front and rear?
For example, it seems to me that if there is a vehicle with 50/50 static weight distribution, double wishbones and identical tires on all four corners, why not have the camber curves of the front and rear suspensions be identical? I'm aware that camber angle with respect to the road affects tire grip and camber thrust and therefore affects understeer/oversteer, but there also appears to be many other ways of adjusting this balance other than by having different wheel cambers.
Thanks in advance!
Thanks in advance!
