Ok ,ladds , been doing a bit of detective work here, and also got some good feed back, from some ..cam manufacturers..
but one thing is clear, the gaps that are given with a cam, all vary, as to what the cam grinder thinks/wants
some say that the gap is needed to ..take..up the gap on a ramp
some say its for thermal expansion
some are saying its both
some are saying that it is because the cams have a lot more lift
but some cams have more lift, and less gaps required,.
all are right , and every one has there own opinion of it
there are so may variables.
EG, My engine, an old castiron lump, the rocker gaps ..doo.. get bigger with a hot engine,
also , when setting the rockers, as stated before, the gaps keep altering, as you turn the engine round, for final checking
this i thought was due to the cam base circle not being a ..circle.., so getting the back of the cam on a high,or low spot, thus altering the setting
this was eliminated, by setting the rockers at the same spot , but still got conflicting readings
but what aboot all the oil on the different parts!!!
cam bearings, cam base/tappet base/push rod ends/inside tappet [full of oil ]/rocker tip/valve tip,.
all are covered in the stuff,
noo when i was setting the rockers, i was getting different readings, so I pushed doon hard on the screw adjuster, and the gaps opened up 1.5 -- 2 thou more
so some thing was getting compressed!!, oil,me tinks,!!!
also when engine had been ..turned over , to re check the rockers, then the gaps would also increase,
this is I think, due to the oil getting ..thinned oot.. by turning over, and no oil pressure to re supply the bearings,
so cam was sitting at the bottom of its bearing, and not supported by as much oil film
and as for pushing doon on the rocker, then i was squashing all the oil oot frae the contact surfaces of the components
Plus , it all depends on how thick your oil is too
so all these things can and doo alter the rocker gap
I actuall ended up setting the gaps to 6 thou, on the original rockers, as 1.5-2 thou bigger when hot, and 2 thou bigger when compressed == the 10 thou OE setting, when not compressed,and cold
on the cam i got noo, and this is where the post was from,
the gaps are to be set at 17--19 thou,
the engine ran noisy with these settings, about twice as noisy the originals set at 6 thou, as stated above
but when i put on the set of 1.65 roller rockers i got [v,v cheap,and new too ] then the engine was a lot quieter
but when , as i found oot, that the gaps had to be increased ,by the amount of extra ratio,
then the gaps went to 19--21 not 17--19 as for original setting for new cam
the extra noise that has come with the 2 thou gaps is a lot,
how can 2 thou diff, make so much more rackett!!
so I have gone and set them to my old formula , as mentioned further back, and took 2 thou off the original setting of 17-19, to end up with 15--17, this should i think still give me enough ..left over gap, to compensate for the extra ratio change
The engine noo, is very quiet, and seems to go as good with a small gap as a big gap
Also as people have siad, the valve timeing has also increased a little
with the big gaps on the roller cam, the ..actuall valve.. was opening at 23 degs btdc, now with my closed gaps its 26 degs btdc, which is not far off, the 28 of what the cam is supposed to do,
So as you can see/read, there are so many variables in a cams gaps specs, that it is best to try and find oot, what works best for you,.
and thanks for all the feed back, well done
regards Marcus
