cliff234
- Aug 28, 2003
- 393
We are designing a multi-family residential structure using floor sheathing over cold-formed steel joists. The sheathing will be screwed to the joists. When we use wood joists, we require the sheathing to be glued and nailed to the joists. Can floor sheathing be glued to cold-formed steel joists? If so, what kind of glue should we specify?
