I would like to know if I can use steel beams instead of rebar for my reinforcement in my concrete footing.
I have a 15'x15'x19" footing and since I have compressive and uplift forces I need to doubly reinforce my footing (top and bottom). However, based on my calculations I need a lot of rebar. I want to know if I replace the rebar with steel beams (that are connected by angles welded to them or running thru them) if I can accomodate for the area of steel required.
Any references, suggestions, or comments are welcome. Thank you.
