Cantilevered CMU Wall - Tension/Shear Interaction for Vertical Reinforcement?
EngineerEIT
29
I'm designing a cantilevered CMU wall (no soil retention) in a high wind region of the US. I've sized my reinforcement for the applied moment due to wind and then I started to think about shear transfer into the footing. Since this is not a load bearing wall, the contribution from friction is negligible and as far as I can see the only way to transfer shear would be through the vertical reinforcement.
I haven't seen any check like this for cantilevered retaining walls, am I missing something?
If so how would I do the check? ACI App D D.7.3?
I'd use the shear friction concept which will have the advantage that you'll be able to double count your flexural rebar as shear friction reinforcing.
