Boiler106
- May 9, 2014
- 211
I've been asked to provide preliminary footing/slab designs for 24 inch thick stacked concrete block walls similar to what you might see in a batch plant for material storage.
These solid concrete blocks get stacked like masonry but do not have vertical reinforcing nor positive attachments from course to course
I am looking for any seismic design resources for these walls using ASCE 7-16 15.6.8 Ground Supported Cantilever Walls or Fences. Specifically, I'm looking to determine the fundamental period.
Using equation 15.4-6 for the fundamental period, it would seem that fi and wi are the same values for a cantilevered wall. Is this correct?
I suppose i can use Ts=Sd1/Sds but these forces are very large even for SDC B.
My concern is that these walls never get designed and Im running a fool's errand to support them. Anyone's input is welcome.
