Cantilevered Wood Diaphragm 1
ltfdrsn
6
I am designing a flexible wood floor diaphragm with a deck. So essentially, the deck will be having a cantilevered diaphragm because there is no shear wall below the cantilevered part of the deck. I would like to get some tips about how to approach to a condition like that.
I was planning to use hold downs.. I would be glad, if there is an example that you guys suggest..
Thanks for the tips..
A sketch of the situation would go a long way to help get meaningful answers.
At only a 5 ft cantilever, I would make sure your diaphragm nailing has enough capacity to transfer the small portion of load into the shearwall and be done with it. It's very long and narrow, I can't see anything that jumps out at me as concerning. Is it transferring any lateral load from walls above?
@jayrod,
There are walls above sitting on the shown diaphragm but not at the cantilevered section.
Then I don't really see an issue, that portion of the floor is essentially just going along for the ride.
