CATIA Automation (VBA, VB.net), Sketch Constraint "FIX TOGETHER"
MarcoSFO
Aerospace
May 4, 2017
5
I have a contour in a CATIA sketch which I would like to move around and rotate. My plan is to fix the geometric elements together to be able to do so without changing the shape of the contour.
Is it possible to create this kind of constraint?
I haven't found anything in AutomationV5.chm and Macro Recording doesn't help neither.
Please help.
Thank you
Hi
You need to modify according to your needs.
Code:
Language="VBSCRIPT"
Sub CATMain()
Dim partDocument1 As Document
Set partDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = partDocument1.Selection
selection1.Search "CATSketchSearch.2DGeometry,all"
CATIA.StartCommand "Fix Together"
End Sub
Fernando
- Romania
- EU
Thank you!
That's a good start I guess but how do i hit the ok button afterwards automatically? The selected items just get referenced in the fix-together command field but it doesn't actually execute the command unless the user hits ok???
Thank you again for your help
AppActivate("CATIA")
SendKeys.Send("{ENTER}")
like this or do you have a better idea? thanks
And another question, is there a method to rotate geometric elements?
Sometimes I have the Problem that my contour is 90° rotated, which is wrong. Now I have to rotate it.
