Catia Macro Find Axis and Face Coordinates
blues1143
Computer
GB
I am looking for a macro to find 2 coordinates of a hole axis and 2 for a face.
I want it to work by running the macro, select axis, msgbox with 2 coordinates, select face, msgbox with 2 coordinates.
Any ideas
Thanks,
Please be more specific (provide an example) about "coordinates of an axis" and "coordinates of a face". A picture would truly worth a thousand words :)
cilici
Okay forget the face for now.
Basically I want to have a button to position a cap screw head into the product by selecting a hole axis and a face.
So when assembling a screw as normal you would bring it into the assembly, then snap the central axis of the screw to the central axis of the hole. Then snap the bottom face of the screw to the face you want it to sit on.
Not sure how I could give a picture. Any ideas?
what is your code so far and where/what is the problem?
Eric N.
Code:
Sub CATMain()
Dim productDocument1 As ProductDocument
Set productDocument1 = CATIA.ActiveDocument
Dim product1 As Product
Set product1 = productDocument1.Product
Dim products1 As Products
Set products1 = product1.Products
Dim product2 As Product
Set product2 = products1.Item("FIXINGS")
Dim products2 As Products
Set products2 = product2.Products
Dim arrayOfVariantOfBSTR1(0)
arrayOfVariantOfBSTR1(0) = Part Location
Set products2Variant = products2
products2Variant.AddComponentsFromFiles arrayOfVariantOfBSTR1, "All"
Dim documents1 As Documents
Set documents1 = CATIA.Documents
Dim productDocument2 As ProductDocument
Set productDocument2 = documents1.Item(Product to Assemble Into)
Dim product3 As Product
Set product3 = productDocument2.Product
Dim products3 As Products
Set products3 = product3.Products
Dim product4 As Product
Set product4 = products3.Item("M8_SOCKET_CAP_HEAD.1")
Dim move1 As Move
Set move1 = product4.Move
Set move1 = move1.MovableObject
Dim arrayOfVariantOfDouble1(11)
arrayOfVariantOfDouble1(0) = 0#
arrayOfVariantOfDouble1(1) = 0#
arrayOfVariantOfDouble1(2) = 1#
arrayOfVariantOfDouble1(3) = -0#
arrayOfVariantOfDouble1(4) = 1#
arrayOfVariantOfDouble1(5) = -0#
arrayOfVariantOfDouble1(6) = -1#
arrayOfVariantOfDouble1(7) = -0#
arrayOfVariantOfDouble1(8) = 0#
arrayOfVariantOfDouble1(9) = 3262#
arrayOfVariantOfDouble1(10) = -390#
arrayOfVariantOfDouble1(11) = 1526.983066
Set move1Variant = move1
move1Variant.Apply arrayOfVariantOfDouble1
Dim arrayOfVariantOfDouble2(11)
arrayOfVariantOfDouble2(0) = 1#
arrayOfVariantOfDouble2(1) = 0#
arrayOfVariantOfDouble2(2) = 0#
arrayOfVariantOfDouble2(3) = 0#
arrayOfVariantOfDouble2(4) = 1#
arrayOfVariantOfDouble2(5) = 0#
arrayOfVariantOfDouble2(6) = 0#
arrayOfVariantOfDouble2(7) = 0#
arrayOfVariantOfDouble2(8) = 1#
arrayOfVariantOfDouble2(9) = 0#
arrayOfVariantOfDouble2(10) = 0#
arrayOfVariantOfDouble2(11) = 0.616934
move1Variant.Apply arrayOfVariantOfDouble2
End Sub
Thats my code so far. Its pretty much just a recorded macro. I had to take some of the titles out (product and file location) but they are fine in my version. How can I automate this so that I click a line and a feature of the screw goes to there... Really I just need a vector of the axis or 2 points on the axis to be able to get the movement numbers seen above.
How can I do this?
you can ask the user to select a cylindrical face, then define a reference out of it. then ask user to select a face and create another reference.
From those 2 ref, get the matrix position for the location of the screw.
in order to get the matrix position you could build and axis based on the intersection of the face and the cylindrical axis...
check this thread560-251808, you might learn from it (like asking user to select face and many other valuable stuff)...
Will come back to you soon
Eric N.
Had a look through this. Looks very useful.
Unfortunately it does not tell me what I want. I think I am going along the right lines now though...
If I select the top circle and the bottom circle of the hole, create a point in the centre then get the coordinates of the points and do math to work out the direction.
Any better ideas?
or you can select the cylindrical face (1 click) and get its axis... which solution you think the user will prefer?
you might also check if something is already selected and if it is a cylindrical face in case the user made the selection first.
But you can go with the 2 circles... it's up to you (in fact 1 circle is enough as a circle is on a plane and the circle axis is normal to the plane...
so did you find in the CPSC how to ask user to select a circle?
Eric N.
Got it to work with the circles!
2 clicks are needed for direction so circles seems the best way to do it.
Do you know how to get the diameter/radius of a circle from selectelement2?
I got creating a point in the circle then modified it so it doesn't append.
check measurable object
Eric N.
