CATIA Macro for Assembly Constraints
ebdulkareem
PK
I have the following CATIA Script that does the following job in the product document:
1. Asks the user to select target points (which are geometrical points and not from a sketch) where they want bolts to be inserted,
2. Retrieves the location of the part file of the bolt from the user,
3. Creates a level 1 product in the tree (i.e., a subassembly),
4. Inserts the bolts in the subassembly as many times as there were points selected in step 1.
Now, every part file of the bolt that is inserted has a geometrical point (which is different from sketch points) in it. I want the macro to add a coincidence constraint to each point in the parent part (that was selected by the user in step 1) with a point in each inserted part. How can I achieve this? Also, I will be working with many other bolts but each of them contains a geometrical point (like described above), so I want it to be generalised. I have very, very little knowledge about scripting macros, and I got the following script from the internet. I would appreciate it if anyone could help.
Code:
Sub CATMain()
'SELECT THE ACTIVE DOCUMENT
Dim mysel
set mysel = catia.activedocument.selection
'CREATE A FILTER SO THAT THE USER CAN SELECT POINTS ONLY
dim myfilter(0)
myfilter(0)="Point"
'TELL CATIA TO PROMPT THE USER TO SELECT THE POINTS
dim mypoints
mypoints = mysel.SelectElement3(myfilter,"Select the target points for insertion of parts",true,CATMultiSelTriggWhenUserValidatesSelection,false)
if (status = "Cancel") then exit sub
'COUNT THE POINTS
for x=1 to mysel.count
set point=mysel.item(x).value
next
'RETRIEVE THE PATH OF THE PART FROM THE USER
Dim strFilePath As String
'DISPLAY FILE OPEN DIALOG BOX
strFilePath = CATIA.FileSelectionBox("Select Part File", "*.CATPart", 0)
'IF USER CLICKED CANCEL (empty string is returned), EXIT THE PROGRAM
if strFilePath = "" Then Exit Sub
dim ofilesys as filesystem
set ofilesys=catia.filesystem
if (not ofilesys.fileexists(strfilepath)) then
'err.raise 9999,,sfilepath & ": This file does not exist."
msgbox "Error: The file does not exist."
else
dim arrayofvariantofbstr1(0)
arrayofvariantofbstr1(0)=strfilepath
dim partdocument1 as document
set partdocument1 = CATIA.ActiveDocument
'Get the Root Product from the Product document:
dim product1 as product
set product1 = partdocument1.product
Dim products1 as products
Set products1=product1.products
'CREATING A SUBASSEMBLY
Dim Product2 as product
Set Product2=products1.AddNewComponent("Product", "")
Dim products2 as products
Set products2 = product2.products
'INSERTING PARTS AS MANY TIMES
dim instancesss
for instancesss=1 to mysel.count
   products2.AddComponentsFromFiles arrayofvariantofbstr1,"All"
next
Msgbox "Parts succesfully inserted." & vbnewline & "No. of parts inserted: " & mysel.count, 0
end if
End Sub
If the links in the previous replies will help you getting the VBA objets and methods to do it, you also need to make your sub-assembly "not rigid". If it is rigid, then you can't constraint more than one bolt to parts outside of that sub-assembly. (You can, but it won't update in CATIA if they are all active).
regards
Thierry
