Catia the startup catalog files in the following list could not be found or captain the wrong inform
FedaykinHandler
12
When i start my assembly in Catia i get a error that follows...
"The startup catalog files in the following list could not be found or captain the wrong information for the active document."
Everythin works but its annoying, how do i get rid of this? (its a large Assembly)
Are you opening a large assembly and then receiving this error?
If you are, then its likely that whoever created that assembly had their own custom catalog and its linked to their own local drive. Check the Tools > Options > Infrastructure > Catalog Editor.
Another thing you can do is check the assembly links. Go to Edit > Links and review all the links, you should be able to find out the problem.
Hope that helps.
