Catia V5-6R2013 View from 3d, Wrong dimensions
julienjj
New member
Apr 23, 2014
I have an issue with a certain part, it is basically a simple extrusion with a few holes.
When I generate a new view from it, the part is all black during positionning and it doesn't display properly : It appear as being too thick. When "flattened" The measurements are wrong in only 1 direction and the part visually doesn't match the catpart (By being too thick).
It is the first time I encounter such weird issue!
Appreciate the help !
Thanks.
It look like that before flattening the view. Once flattened, any pocket, holes or chamfers are missing
Hi julienji,
Please try this option. Goto tools...options...mechanical design...drafting...view...generate 2D under view from 3D.
There might be other reasons also.only we thoroughly check the system can we predict the issue.
