CATIA VBA : Get instance name path from selected item to root product
MichalPon
Industrial
GB
I have issue with getting instance name path of selected item to root product.
Result that I want to get from CATIA in this case is string with the following path: "Product2.1\Part2.1"
Additional thing is that CATIA tree will be not known in the future. Getting path formula should work with different multilevel trees.
Simple CATIA tree:
!Product1!
+- Product2 (Product2.1)​
+- Part1 (Part1.1)​
+- Part1 (Part2.1) <- Selected Item by user​
VBA Code:
Dim Sel1 As Object
Dim Filter1(0)
Dim Status1 As String
Dim objSelPrd1 As Product
' [ Part Selection ] ***
Set Sel1 = CATIA.ActiveDocument.Selection
Filter1(0) = "Product"
Status1 = Sel1.SelectElement2(Filter1, "SELECT PART", False)
' [ Switch Part to Design Mode ] ***
Set objSelPrd1 = Sel1.Item2(1).LeafProduct
objSelPrd1.ApplyWorkMode DESIGN_MODE
MsgBox Sel1.Item2(1).LeafProduct.Name 'gives result "Part2.1"
MsgBox Sel1.Item2(1).LeafProduct.Parent.Name 'gives result "Products"
MsgBox Sel1.Item2(1).LeafProduct.Parent.Parent.Name 'gives result "Product2.1" but I don't know how many levels CATIA tree will have in different products
So I'm searching for a solution to get whole path as string from Part chosen by user no matter of CATIA tree complexity - in this case "Product2.1\Part2.1"
Thanks in advance,
Michal
once you get level up with object.LeafProduct, did you try to go up more level with object.LeafProduct.LeafProduct?
Eric N.
I try this configuration and it's not gives proper results.
did not try hard enough...
Code:
Sub catmain()
    Dim Sel1 As Object
    Dim Filter1(0)
    Dim objPrd As Product
    Set objPrd = Sel1.Item2(1).LeafProduct
    fullpath = objPrd.Name
    While Not reachroot
        Set objPrd = objPrd.Parent
        fullpath = objPrd.Name & "\" & fullpath
        checkParent = ""
        On Error Resume Next
        checkParent = objPrd.Parent.FullName
        On Error GoTo 0
        If checkParent = CATIA.ActiveDocument.Name Then reachroot = True
    Wend
    MsgBox fullpath
End Sub
Eric N.
Thanks for developing code but there is still something wrong.
When I try to use it as CATScript I get infinite loop. In other case when I try to use as VBA I was asked to add a few dims but even after that step I not received MsgBox, macro just stops/crash without it.
Dims that I added:
Dim fullpath As String
Dim reachroot As Variant
Dim checkParent As String
what line ? what error message ?
Eric N.
On this line in While loop:
Code:
Error msg:
Run-time error '13':
Type mismatch
Problem solved. Correct VBA code:
Code:
Sub CATMain()
[indent]Dim Sel1 As Object[/indent]
    Dim Filter1(0)
    Dim objPrd As Object
    While Not reachroot
        checkParent = ""
        checkParent = objPrd.Parent.Name
    Wend
    MsgBox fullpath
End Sub
