Hi, absolutely first time here and first post. Pardon me if I mess up some protocol.
For years I've used some macros in CATIA V5 to change the background colour. I use white, black, and blue backgrounds, with a toggle for the screen fade. This is simply much quicker than going Tools -> Options -> Visualization, etc.
They've worked fine for years, now they're suddenly crashing. The code is below. The line that is crashing is "Dim visualizationSettingAtt1 As VisualizationSettingAtt", as it says "User-defined type is not defined". This implies CATIA removed a previously-existing data type. Obviously my first go-to was the macro recorder, which I ran, which generated the exact same code! Meaning, even macro recorder-generated code crashes. How is this even possible?
Any thoughts?
Edit : Probably should include.... CATIA V5-6R. Build day 08-26-2020.11.00. Service pack 4, Build Number 28, Hot Fix 65. This macro worked until the last week or two.
Edit 2 : Lol, apparently "Dim tmpDWGFile As DrawingDocument" no longer works either, same error. Seems like almost all of my macros are now broken.
Any thoughts?
Code:
Sub CATMain()
Dim settingControllers1 As SettingControllers
Set settingControllers1 = CATIA.SettingControllers
Dim visualizationSettingAtt1 As VisualizationSettingAtt 'This line crashes
Set visualizationSettingAtt1 = settingControllers1.Item("CATVizVisualizationSettingCtrl")
Dim double1 As Double
double1 = visualizationSettingAtt1.AntiAliasingOffset
visualizationSettingAtt1.SetBackgroundRGB 0, 0, 0
visualizationSettingAtt1.SaveRepository
End Sub
