RWW0002
- Jun 10, 2011
- 373
I am verifying the capacity of a jib crane boom arm (see attached sketch). The crane arm is free to swing 180° about the column, and the hoist load acts at the bottom flange of the boom arm. The design is fairly straightforward with some conservative assumptions concerning unbraced length and Cb (beam stability factor).
However, for the attached jib boom, I am wanting to take advantage of Cb>1.0 for the section of the boom between the support rod and the column (node A to node B in the sketch). From the AISC spec and commentary, it is implied that the Cb equations and published values are only valid for sections of members "between brace points." There is definitely not much in terms of lateral or torsional bracing for a jib crane. I know that Cb should be 1.0 (or possibly <1.0) for the unbraced cantilever portion of the arm (between B and C), but is Cb=1.67 (Calculated from AISC Eq F1-1) justifiable for the portion of beam between nodes A and B?
Thanks in advance for your thoughts.
