CBR % from Clegg Readings
JintyMc
I have a set of clegg impact values (CIV) which i have obtained and recorded and I need to convert them to %CBR Values.
I have used the following formula on each CIV that i have recorded and have the results from them.
% CBR = 0.07(IVxIV)
An example of a result I am getting are as follows:- 0.07(59 x 59) = 243.67
Does this mean that the CBR % is 243.67%? or am I wrong?
I have some Design Specifications that require CBR Value of 30% but all my results are throwing out HIGH readings after the equation so its throwing me alittle.
Can anyone help?
It would be interesting to know the types of soil/road base (etc) you are dealing with. I've never used the CIH but there are different weights . . . Are you sure your Clegg Impact number is 59 and, perhaps, not 5.9?? Clegg's chart doesn't go that high from what I can see. Also, as with many correlations, one should try to get a correlation for their particular site (i.e., site specific) or area.
Just wondering if you ever did a google search?
(see page 3)
Basically i have undertaken clegg readings at 20m intervals along an old existing stone farm track which I intend on laying tarmac on.
the ground is stone and compacted like concrete and so the readings which i have are high. these readings are correct as there are no decimal places in the readout screen. Clegg hammer used is : 4.5kg CIST/882 CLEGG IMPACT SOIL TESTER.
Then the CBR is meaningless.
Anyway to prove that there are no "soft spots" in the "track" - I would presume that it wasn't an engineered pavement structure so you might get variations from place to place.
You might have better luck doing a Benkelman Beam study - it will tell you the deflections at the test locations along the track - which would tell you how much additional pavement structure is needed. (I chose the BB since it is likely more readily available than a falling weight deflectometer).
