RyreInc
- Apr 7, 2011
- 205
Greetings,
I've been tasked with finding the stresses on a cylindrical part, to be rotated at high speed. I don't need a precise answer, but a worst case scenario is a good place to start.
I've found a source (patent 5015940) that gives an equation for centrifugal pressure for a thin-walled cylinder, as well as a few sources that provide hoop stress for a thin-walled rotating cylinder.
However, wall thickness is 35% of radius, and I haven't had luck deducing a formula that combines pressure/force from rotation with a thick-walled body.
Intuition tells me that stresses will be greatest on the outer surface, and the stresses of a thick-walled cylinder should be less than or equal to those of a thin-walled equivalent. Are these assumptions correct? If not, how should I proceed?
Thanks!
Thanks!
