jph90
- Jul 27, 2016
- 23
Hi guys,
Currently we are installing a process plant that features a closed hot water loop. There is effectively an atmospheric holding tank, that loads out directly to the suction of a centrifugal pump discharging to the various process applications. The flow in the supply line not used/returning from a heat exchange application then returns to the holding tank and the process repeats etc etc. The tank is complete with low level switches etc to ensure pump doesn't run dry.
A question popped up today around the installation of an air release valve on the discharge of the centrifugal pump. This is highlighted in a rev cloud on the attached sketch. I am curious as to why this would be required, given there is one on the return header (ultimately the same line) which is also the highest point in the system. A few things i want to run by you are:
- is an additional air release valve required on the immediate pump discharge or is the current air release adequate to protect the pump?
- if we were to add an additional air release, is this the best place for it?
Effectively i dont think it is required and the current set-up is adequate. Just want to check if i am missing something
Thanks in advance
Thanks in advance
