hdp321
- Nov 3, 2006
- 31
I know when designing wood panel shear walls it’s common to utilize the floor framing DL and self weight of wall to counteract overturning, at least a portion of that load is used.
Is using the DL common practice for Flat Strap shear walls in metal stud building as well? Most of the software on the market does not account for this unless you enter chord compression loads manually, so it got me thinking that perhaps the loading is not commonly considered in CF buildings.
