RFreund
- Aug 14, 2010
- 1,885
In regards to say 3-5 story cold formed steel or wood framed structures for condo/hotel/multi-family type structures. Does anyone use thickened slabs for interior bearing walls? How about if they also act as shear walls?
In my particular case all the foundations will be on vibratory stone columns.
My concerns are:
Uplift resistance at shear walls.
Differential settlement where the thickened slab meets the exterior wall.
We are working with a contractor who has stated that they are using thickened slabs for a couple 5 story structures currently. I suppose the differential settlement may not be an issue because of the vibratory stone columns. Also I could size the thickened slab for bearing pressure and possible check to see what is required for uplift. Although uplift seems like a long shot...
EIT
My concerns are:
EIT
