SolidCreative
- Jul 27, 2004
- 143
I’m trying to calculate sprockets for a chain drive powering a belt transfer conveyor.
Things I known are:
Motor RPM 1800
Gearbox reducer ratio 1:8
Conveyor belt linear speed 100 ft/min
Conveyor belt drive pulley dia 7 inch
Horsepower (assumed) 10
One of the two sprockets will be bolted directly onto the conveyor belt drive pulley, which will drive the belt. The other sprocket will be mounted on the end of the gearbox shaft.
Is this enough information for me to make a selection for what sprocket sizes to select?
Thanks for any information you may be able to provide me
Matthew
Things I known are:
Motor RPM 1800
Matthew
