Change the transparency of the selected part using a journal
neshom
43
I am new user and this is my first journal.
I'd like to have a button to set the translucency of the selected part to 70%. I have recorded the following journal, but it basically does it only for the part that was selected during the record procedure:
Code:
using System;
using NXOpen;
public class NXJournal
  public static void Main(string[] args)
    NXOpen.Session theSession = NXOpen.Session.GetSession();
    NXOpen.Part workPart = theSession.Parts.Work;
    NXOpen.Part displayPart = theSession.Parts.Display;
    //   Menu: Edit->Object Display...
    NXOpen.Session.UndoMarkId markId1;
    markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Edit Object Display");
    NXOpen.DisplayModification displayModification1;
    displayModification1 = theSession.DisplayManager.NewDisplayModification();
    displayModification1.ApplyToAllFaces = true;
    displayModification1.ApplyToOwningParts = false;
    displayModification1.NewTranslucency = 79;
    NXOpen.DisplayableObject[] objects1 = new NXOpen.DisplayableObject[1];
    NXOpen.Assemblies.Component component1 = (NXOpen.Assemblies.Component)workPart.ComponentAssembly.RootComponent.FindObject("COMPONENT model3 1");
    objects1[0] = component1;
    displayModification1.Apply(objects1);
    displayModification1.Dispose();
    //   Menu: Tools->Journal->Stop Recording
  public static int GetUnloadOption(string dummy) { return (int)NXOpen.Session.LibraryUnloadOption.Immediately; }
Could you please guide me on how I can change it so that it validates the variable component1 to the selected part instead of the part named "model3"?
Thanks in advance.
You need the vb code to act on a selected component, instead of the one recorded in your journal.
I suggest you get one of our samples, and adapt it.
If you search our knowledge base for Sample NX Open .NET Visual Basic program selected component you will see several that would make a good starting point.
Mark Rief
NX CAM Customer Success
Siemens PLM Software
Try this code:
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Module changeColorOfPreSelectedFaces_v2
    Dim theSession As Session = Session.GetSession()
    Dim sel As Selection = NXOpen.UI.GetUI.SelectionManager
    Sub Main()
        '' The selectFaces method takes an NXobject array by reference
        Dim selectedObjectsArray() As NXObject
        Selectbody(selectedObjectsArray)
        '' Need to recast the face NXObjects to Displayable objects
        Dim faceArray(selectedObjectsArray.Length - 1) As DisplayableObject
        For i As Integer = 0 To selectedObjectsArray.Length - 1
            faceArray(i) = CType(selectedObjectsArray(i), DisplayableObject)
        Next
        Dim changeBodytransluency As DisplayModification = theSession.DisplayManager.NewDisplayModification()
        With changeBodytransluency
        '    .NewColor = newColorCode
            .NewTranslucency = 40
            .Apply(faceArray)
            .Dispose()
        End With
    End Sub
    '' The following routine is from GTAC
    '   sub to select faces
    Sub Selectbody(ByRef selectedObjects As NXObject())
        Dim ui As UI = NXOpen.UI.GetUI
        Dim message As String = "Select body"
        Dim title As String = "Selection"
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
        Dim keepHighlighted As Boolean = False
        Dim includeFeatures As Boolean = False
        Dim response As Selection.Response
        Dim selectionAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim selectionMask_array(1) As Selection.MaskTriple
	With selectionMask_array(0)
            .Type = UFConstants.UF_component_type
            .Subtype = UFConstants.UF_component_subtype
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
        End With
        With selectionMask_array(1)
            .Type = UFConstants.UF_solid_type
            .Subtype = 0
	End with
        response = ui.SelectionManager.SelectObjects(message, title, scope, _
                                         selectionAction, includeFeatures, _
                                     keepHighlighted, selectionMask_array, _
                                                      selectedObjects)
        If response = Selection.Response.Cancel Or response = Selection.Response.Back Then
            Return
        End If
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        GetUnloadOption = NXOpen.UF.UFConstants.UF_UNLOAD_IMMEDIATELY
    End Function
End Module
With best regards
Michael
