Terrytubby
I have a drawing that I need to change the size of the Section Line arrow heads. I can change the setting via Preferences, Section Line Display, but none of the existing sections update and I can not go through and re-section everything. Is there a way of making UG update all the existing sections?
Also, when I click on the default button on the settings dialogue box, it reverts back to the old setting. Is it because the original .def has not changed yet and could this be causing the rest of the views not to update.
A better way for ourselves, if possible, is after changing the customer file, replacing the settings stored inside the drawing and then to have the drawing update automatically, as we may have a lot more changes to make with regards to font styles and line widths? Can this be done?
TIA
TIA
