Changing ID in ST1.
jheal2
39
Hey guys.
I have an ID that needs to be smaller. I drew it as a sketch and revolved it to make my form and only 1 diameter is wrong. I was wondering if I could quickly make it smaller without having to make a new sketch and revolve it again and so on.
Their has to be a simple steering wheel function to change Diameters, I just can't figure it out.
Jordan.
I've not used sync mode but I believe you put a dimension on one edge of the cylinder and then change it.
(It's a really poor way of doing it and hopefully it will be changed in the future so that you just click the cylinder and be presented with the radius/diameter dimension so that you can change it).
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
