  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Check Hotkeys 1
akhtar07
59
Hello Guys,
Is there anyway to check the list of hotkeys that have been set in CATIA ?
Either default or custom done !!
Warm regards,
Akhtar Aziz
Where can I find that pull down menu View ?
Warm regards,
Akhtar Aziz
Eric N.
well that is not useful. :/
Warm regards,
Akhtar Aziz
Well you ask the location of the view menu
Eric N.
hahaha.. thanks mate
no worries, don't get offended ... i know that was a weird reply from me !!
Warm regards,
Akhtar Aziz
SORRY
in fact I should have looked your question and the provided answer....
the all command functions in the view menu does not list the shortcuts [upsidedown]
you have to go in customize function and then you have access to the shortcut info:
Eric N.
If you know a little vbscript you can search in CATRsc files something like (bellow is just an example)
// Shortcut
ACOClaCreationWbenchHeader.FSFlipCompassBaseHead.Accelerator = "F5";
ACOClaCreationWbenchHeader.FSSetCompassHead.Accelerator = "F6";
ACOClaCreationWbenchHeader.FSResetCompassHead.Accelerator = "F7";
// meme short-cut utilise par MainDialog pour modif de selection
//ACOClaCreationWbenchHeader.FSDropCompassPlaneHead.Accelerator = "F8";
So, search inside those files keyword Accelerator and extract all the lines in a list (then you can share with us if you want). And indeed , I've done a confusion, in v6 you can see the shortcut keys in Commands List pull down menu...
Fernando
- Romania
- EU
