Pumpinterest
- Jul 21, 2005
- 5
Anybody has ever seen a check valve installed in the suction line of a centrifugal pump? I am now in a design project, we have a buffer vessel for a centrifugal pump and the bypass line for the buffer vessel, in normal condition the centrifugal pump the fluid through the buffer vessel, but in abnormal condition the buffer vessel will has to switch to the bypass line. To prevent the fluid reverse to the buffer vessel we desgin a check valve in the outlet of the vessel. I want to know, if I consider the pressure drop of the check valve to ensure the NPSHA at the pump suction point above the NPSHR, is there any problem to the centrifugal pump.
Can anybody answer me,if that I will appreciate your help very much.
