Checkmate - suppressed components
lklo
Industrial
Nov 24, 2010
226
Hi -
Do anybody here on board , know if it should be possible to check for suppressed components in a NX assembly.
I'm running NX 8.5...
lklo
Try this basic checker:-
Cheers, NXJ
#! NX/KF 3.0
DefClass: check_for_suppressed_comps ( %ug_base_checker );
( String ) %test_category: "MyCustomChecks.Modelling";
( String ) %displayed_name: "Check For Suppressed Comps";
( Boolean Parameter ) Disabled?: False;
( Boolean Parameter ) save_log_in_part: False;
# Attributes for this class
( List Modifiable ) assy: ug_askAssemblyComponents( );
( List Modifiable ) violations: Loop {
For $a In assy:;
For $b Is mqc_isComponentSuppressed( $a, "lib", "libufmqc", "Name", "mqc_ufkf_is_comp_suppressed" );
If ( $b = 1 ) Collect $a;
# Checker function
(Any Uncached) do_check:
If ( (-Empty?(violations:)) )
Then (mqc_log( LOG_ERROR, violations:, "Assembly contains suppressed components"))
Else (donothing);
Hi -
Thank you so much for sharing this checker....
-I will use your checker sample as a starting point for me...
In my case I only need to check for components in current workpart - what I mean is only 1.level of assembly..
I have done this in a checker where I call a external NXOpen program (compiled VB) and return a list into the dfa checker.
But runtime is slow by doing it this way - and I will try to do all the stuff inside a dfa checker, without "leaving" dfa and go to a external program...
lklo
Hi
On assembly navigator right click on the top bar
And check the box of "include suppressed component "
Maybe that's not your intentions but it shows
The suppressed component in blue.
hi -
thx - and yes your are right...
But I will run checkmate on thousands of parts in one shot, and need checkmate to help with this...
lklo
Ok,
This version will only check the immediate children of the parent assembly.
Hope this helps,
Cheers,
NXj
#! NX/KF 3.0
( List Modifiable ) assy: mqc_askImmediateComponent( "lib", "libufmqc", "Name", "mqc_ufkf_ask_immediate_component" );
For $a In assy:;
# Checker function
Else (donothing);
hi again -
I was not aware about this predefined function > mqc_askImmediateComponent..
But excellent checker you shared....
thx so much...
lklo
