BKB001
- Oct 4, 2006
- 8
I am trying to design a clean sheet front (and rear, but one at a time) SLA suspension without a lot of constraints. I have been through this thread and learned a lot of valuable things, but I am still missing some fundamentals.
The suspension will go into a small light car (think Austin Healey Sprite) that will most likely be slightly overpowered and used mostly on the street with a few trips to local autoX and roadcourses.
My intentions were to provide a KPI of around 14 degrees and a castor angle of around 7 (I have heard that if KPI is twice castor that the camber curve will remain constant while turning). That may be too high, but please let me know.
The main question is about the camber curve. My first draft thought is to make the camber curve exactly follow the body roll with a little extra negative camber (1/2 degree or so) beyond. On a track width of ~45 inches, this means that at 3" compression, the tire should have around 8 degrees of negative camber. This seems excessive. Am I missing something? Is the goal reasonable?
Also, don't think that I forgot about RCs, but given the controversial nature of them on this forum I was going to leave them be for now.
Thanks in advance!!
Brian
Thanks in advance!!
Brian
