Chrysler Welding Bolts - Projection Welding Standard ? 2
richards49323
5
Greetings, I have Chrysler Process Standard for welding nuts but not for welding bolts.
I have 2 stampings (1.5mm thick) that I am welding a M6x1 weld bolt in. Need guidance on push-off capabilities.
Thanks,
richards49323
Chrysler Process Standard PS-1791 WELD SCREWS - PROJECTION WELDING. For M6 in 1.5 mm thick steel, the minimum strength requirement is 10230 N.
Good Morning, Would you by any chance of a copy of this, Chrysler Process Standard PS-1791 WELD SCREWS - PROJECTION WELDING.
I cant seem to locate it.
Thanks again,
richards49323
