I'm using Civil 3D 2008.
Most of the time, when I try to move or delete Annotative Text or Dimensions, Civil will not respond to the command.
I have identified 3 cases:
1.- The move or delete simply does not occur.
2.- Civil says that the object is open for editing, and will not complete the action.
3.- Trying to edit Mtext, an "Internal Error: Cannot open MTEXT object to write changes. Please contact techical support... " message appears. It does not shuts down C3D.
If I close and open the drawing, edits run flawlessly... Until I use some other commands and the problem returns.
Any known solution on this bug?
RGuerra
RGuerra
