zoltecrules
Greetings-
I recently recieved some samples of 6061-T6 Aluminum from a anodizer that were given this military specification: MIL-A-8625F Type II Class I. They showed up like this:
If you can't see, the finish is very bad. Basically it has these water spots that my customer will NOT accept. What I was wondering is:
1. Is finish typical for the spec I called out above?
2. If so, is there an additional etching spec I should be calling out to prevent this?
Thanks in advance
Thanks in advance
