clear height control
swelm
70
hi
we have column in the middle of the building the column with dimension is 300mm x 600mm
the width 300mm in unsafe buckling length in the ground floor in case of we consider the clear height of column start from top of foundation until the bottom of beam in first floor
but if we consider the clear height start from the ground floor level up to the bottom of beam in first floor the column will be safe
my question is ?
how can I make the clear height start from the ground floor without adding beam in ground floor?
my idea to make pedestal 600mmx600mm
is that good idea?
thanks
best regards
i surprised because nobody answer me
is my question is hard for people have experience
anyway thank you
