  • Congratulations 3DDave on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
clogged suction or discharge pump linr
Thuba
Chemical
Nov 21, 2024
54
Say l have a clogged discharge line, the pump current drawn by a pump should not drop; just as starting a pump with discharge valve closed (0 flow). Also a clogged suction line shouldnt result in less current drawn since flow is low. l am confused as to how both cause increased current drawn?
Please define clogged.
block
Think about power.
Pumping against a closed line obviously requires more power.
ok thanks, how about a clogged suction, needs more power? l want to have a way to know if its the suction or discharge clogged, by just measuring power
This doesn't make sense at the moment.
Pump current should not drop?? Drop in realtion to what? Running current? start current?
Less current since flow is low?? Less than what?
I don't think you're going to find out from power what is going on. Listen to the pump. If the inlet is blocked it will be cavitating like mad. If the discharge is blocked it wont.
You are better off using pressure guages...
Or just removing the blockage from both ends
It would be helpful for all if you stated the type of pump in question and the min/operating/max "current" for your application. If its a PD pump, yes, the current will increase as the pump struggles to maintain the volumetric displacement. A centrifugal pump can still output higher pressure albeit at a lower flow rate but depending upon how sensitive your current measurements/thresholds are you might see an increase. Are you attempting to determine clogged status based upon pump current drawn? Obviously the goal for pumping is to not block the inlet or outlet line, measuring differential pressure across a strainer/filter or monitoring pump flow rate/pressure would be belter ways to detect line/element fouling.
Look at your pump curve.
If you're talking about a centrifugal pump, typically, the shut off head power (power pumping against a blocked line) is NOT the highest power point. Tyically, it's at run out (pumping against a wide open discharge).
For some, such as axial flow pumps, it will be at shut off.
You need to look at the power curve for the actual pump you are investigating.
My first question is: is the pump a dynamic pump or a displacement pump? My second question is the same as LittleInch: what is the baseline to which you are comparing?
