Close surface error
sudhakarn
Automotive
Apr 1, 2013
506
Here is one more doubt. When i try to convert a complex surface to close surface to thick surface ,i often get errors. how do i rectify that? Any help is greatly appreciated.
P.S: Error is often "non manifold geometry found ".
There is no sure-fire way to say what is wrong, if you have access to it the "Healing Assistant" workbench can help in identifying and rectifying the problem regions.
There is a gap in your surface. You can spot it by turning on surface boundaries in your options (general/display/visualization). Or create a surface boundary curve and look for curve elements where they shouldn't be.
Thank you so much tdutton. visualisation option was very useful.
If you are using the "thick surface" function, you need to make sure that the boundaries and curvature of the surface selected is suitable for the offset value used. If you are getting a "non-manifold" error, the best thing to do is find the location of the error, and then carefully reconstruct the adjacent surfaces one by one to resolve the discontinuity error.
