Code Boundry and S vs SA/SB 1
PipingEquipment
81
Am planning on removing a pair of flanges connecting two vessels via a 12" sch10S piece of pipe and replacing with a pup piece of pipe (eliminating the flanges as they leak in a high heat and high caustic service), my question is since Section VIII specifies that the code is ended at the first weld does that mean the pipe I want to weld in between the two vessels can be considered B31.3? I ask because I can only find the nickel alloy in B-xxxx not SB-xxxx, and as I understand it ONLY SB-xxxx (or SA-xxxx) can be used for code vessels, or alternatively is there any way around a material not double stamped for B/SB without re-certifying it to SB standards?
Also, the Section VIII portion ends at the first weld, but is the weld included, in other words can a SB pipe (Section VIII side) be welded to B pipe (B31.3 side)? Or would the first weld have to have BOTH pieces of pipe be 'pressure vessel quality' (SB)?
Thanks for your input and help.
Here is what Section VIII, Div 1 states;
U-1(e) In relation to the geometry of pressure containing
parts, the scope of this Division shall include the
following:
U-1(e)(1) where external piping; other pressure vessels
including heat exchangers; or mechanical devices, such
as pumps, mixers, or compressors, are to be connected to
the vessel:
(a) the welding end connection for the first circumferential
joint for welded connections [see UW-13(h)];
(b) the first threaded joint for screwed connections;
(c) the face of the first flange for bolted, flanged
connections;
(d) the first sealing surface for proprietary connections
or fittings;
(a) would be applicable in your case because you would have a butt weld to the section of pipe sticking out from the vessel.
So at that first weld where the BPVC ends, can an SB (section VIII) material be welded to a B (B31.3) material?
