Coeifficient of Friction
FRICTIONX
Materials
Jan 22, 2020
3
I want to use small metal balls to grip a steel wire that is tin plated.
The metal balls are sliding against the tin plated steel wire.
The balls are forced to impinge on the tin plated wire and grip it.
What material or plating for the balls would be best to have the highest possible Coefficient of Friction.
Also, what about the possibility of using a non-metal ball like hard rubber, ceramic, glass, etc. Thanks
What happens if the wire is dented by the balls?
How hard is the wire?
Single stand ?
What is the variation in wire diameter?
If you want to really secure the wire or tug on it you may need to use a collet.
Tempered high carbon steel. We do not think the string will be dented. The balls act like the arms of a collet. Mostly wanted feedback on the Coefficient of friction in regards to using different materials such as copper, aluminum, ceramic, brass, hard rubber. Thanks for the feedback.
Can the balls mark the tin plate? If yes then you could have the balls coated with an abrasive media like sand paper. If not then perhaps a hard rubber would be best. How long do the balls have to last, how fast is the wire running, how much load? Lots of unknowns here.
The amount of friction depends on how much pressure is applied, so all materials can potentially provide exactly the same amount of friction.
Might as well ask for the slope of a line given a single point.
LinkLooked into coatings, but was told by the companies that the balls were too small to coat. I am leaning toward testing hard rubber.
