Color fill a drawing sketch 1
Mikedk64
18
Hello.
First, sorry my bad english.
Can anybody help me with my problem.
I have a sketch in my draing, and i want to fill it with red color. Is there anyway to do this?
Use area fill (Insert -> Annnotation -> Area Fill), in settings change Pattern to solid fill colour red, then just click in the sketch (if selection option is "Point in Region").
Best regards,
Michaël.
NX7.5.4.4 (NX8.5.3) + TC Unified 8.3
Win 7 64 bit
Please try to switch of monochrome view of drawing. RM on Drawing in Part Navigator, uncheck monochrome...
Best regards,
Michaël.
Win 7 64 bit
I just have one follow up.
When I uncheck monochrome turns all lines to blue.
Is there a way to change the line color to black?
If you're not using Monochrome display, you'll need to use 'View Dependent Edit' to change the color of all of the Drawing curves to Black.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Or...
Edit your view style, on the "visible lines" tab, change the color to black; repeat for "hidden lines" and "smooth edges".
If this is something you will use often, change your template parts and/or customer defaults to the desired colors.
www.nxjournaling.com
Yea, I forget about that approach. Good call Cowski...
Actually this is a much better solution since any new curves will automatically update to black as well. And, as mentioned, if this is going to be your normal style of output, you can preset these colors in Customer Defaults or when you create your templates.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
