Column (Pile) and beam (Waler) connection fixity in a shoring system 1
Ehsan Ben
7
Hi everyone,
I am modeling a shoring system consisting of soldier piles and walers in RISA3D. My question is about some connections between a pile (column) and a waler (beam). As shown in the attached image, the waler and pile are next to each other (kind of overlapping) and not a center-to-center connection. They want a connection where waler and pile overlap and no moment can be transferred between waler and pile. So I was wondering how I can model this connection in RISA3D.
Thank you for your suggestions and responses.
Ehsan
 https://files.engineering.com/getfile.aspx?folder=df0ba453-65ff-4dc4-969f-71fb9e3172f5&file=IMG_1750.JPG
I've always idealized these connections as pinned. I'm not sure if I'm missing your question, but there should be a way to release whatever moment you're finding is transferring through the connection. If desperate, I've previously put a gap between two members and connected them with rigid link that is fixed to one member and pinned to the other. That usually eliminates any moment transfer.
Actually, you're right. I tried a rigid link (one end fixed and the other end pinned) and it works perfectly. Also, I asked this RISA support team and they responded with the same solution.
