column/plate sizing and verifying 2
Pimech
27
Hi!
I should verify (and eventually resize) the following column.
It is made by a bottom and a top plate with two squared steel tube 200x200x10mm (welded to the plates). Please see attached sketch.
The bottom plate will be fastened to the floor through bolts.
I should choice bolts number and position.
How could I proceed? Any advice is welcome.
Thank you
 https://files.engineering.com/getfile.aspx?folder=f6218a99-f0b8-4a75-b5fb-04b2ade9f7a2&file=Immagine.png
Nor have I dik... first high seismic design of baseplates and my counterparts said sounds about right. Feels crazy big to me, but my understanding of crazy big is being re-defined.
S&T
Wow! Out of curiosity what are the plan dimensions of the base plate? And what column section?
strucbells, i will start a new post in a bit after I finish off my stiffened design... do not want to derail this one.
S&T
Sourcing the steel for a 7" thick base plate may become a problem. In the utility industry for large mono poles a base plate of that thickness is not unheard of - usually with 2 to 3 anchor bolt circles around the pole. However, that is the thickness you start seeing fabricators start to use forged ring plates rather than discrete plate.
