I have a simple pin/pin column that needs to be installed in two pieces. What would be the criteria for the splice. Obviously I don't want another pin cnx at the splice, but I'd rather not develop the full moment capacity either.
I realize that I'll need to put some nominal load laterally just for things leaning on the column. Also, I'll Fix the base as much as possible since that will make installing the upper sections easier. But, I'm uncertain if there's a rational method for the spice without other considerations.
Would using 2% of the axial force apply? (in my particular case I'd use more)
It's more of a post than a column . . about 14' high, maybe 6x6 tubes with less than 10 kips. But it is repetitive so I'd like to be economical.
Thanks,
Rich
Thanks,
Rich
