1
- #1
I have a steel column that requires a 1 1/4" Base Plate by design.
The contractor would like to use his 3/4" plate he has in stock to make the base plate.
I would like to double up the plates to make a 1 1/2" base plate. Other then using a groove weld along the plate perimiter to connect the two plates, what other criteria should I consider in welding the two plates together so both act as ONE 1 1/2" plate? Could you please point me to code references in regard to this issue.
Thank you all,
Jeffrey Krus P.E.
Thank you all,
Jeffrey Krus P.E.
