Complicated Swing Hatch (Flat Head) Design - ASME VIII, Div 1, Custom Flange
Doodler3D
188
ASME Stalwarts,
I'm working on a pressure vessel with a hatch that also functions as an unstayed flat top head. Based on my reading here, I get a hint that one has to work with the mandatory appendix - 2 and treat this as a loose ring flange. However, there is metal to metal contact with a central plate sandwiched between the flat head and the flange, which possibly leads to Appendix Y. Any advise on this one? Should I treat the flat head and central plate support as one?
Thank you.
SS304L Construction, 100 psi design pressure.
DoodlerDaru, ignoring the "central plate" (what's that for?) I'd say Apx Y, Class 3, Cat 3 applies.
Swing bolts? See Apx 2, definition of "A". Don't know if Apx Y has provisions for this or not.
Mike
Thanks Mike, the central plate (same ID/OD as the flat head) supports swappable guide vanes for a paddle mixer. I have to throw the kitchen sink at this one since the original design/calculations followed BS 13445-3 (lost/missing) and now needs ASME VIII calcs. Looks like ASME VIII, App. Y seems to be correct, as you suggested.
You probably meant (BS) EN 13445-3, correct?
Huub
- You never get what you expect, you only get what you inspect.
Hi, you can use the Appendix Y to verify the flange in Gasket seating condition, but the flange should be verified in Appendix 2 for the operating condition :)
@XL83NL yes, BS EN* 13445
@u236 If Appendix Y assumes metal to metal contact, the gasket would not generate any moments. I'm a bit confuseD when you say ' Appendix 2 for operating conditions'.
u236, I think you are mistaken. Appendix Y anticipates negligible gasket seating loads, therefore the design necessarily considers operating conditions. See Y-1(b). See Y-1(c) for why Appendix 2 is not suitable for this type of flange.
