  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Composite beam in STAAD
Bill2001
33
I am trying to model a composite beam (steel beam + concrete slab).
For this purpose I modeled my composite beam as a steel beam and plate elements.
I applied then an offset distance 0.95 m to the steel beams.
Now I see that the steel beam gets a very large axial force and the Mz moment at the mid span is very small!!!
I am really confused the way STAAD calculates section forces.
Do you have any clarification on this?
Do you have any sample for a composite beam used in STAAD (built-in Composite Deck)? Could this feature used on user defined beams such TAPERED?
I have uploaded my input file.
Thank you
Bill
Ed,
Thanks for your help.
Could you please say why I have to change the support?
Bill
Ed,
Thanks for your helps!
I don't know why we should model the structutre this way.
Don't you think this is a limitation in STAAD?
When you use Digital Canal Composite Beam, do you also get so large axial forces in the girders?
BTW I see you are an advanced user of STAAD using REPEAT in your input file.
Bill
Bill,
I agree that this is a stretch for STAAD. The Digital Canal Composite Beam program is much easier for this problem.
Ed
