I've been scouring the internet all afternoon looking for some insight into a true position callout we are dealing with.
I am trying to inspect a threaded hole pattern (20 holes equally spaced around a circle) to the following composite true position:
[TP|0.0157|E|C]
[ |0.0157]
Datum -C- is a diamter, along the same axis at the bolt circle, while Datum -E- is a diameter, which is perpindicular to the bolt pattern, with the axis intersecting that of datum -C-
From my understanding, the top portion of the FCF is the position of the bolt pattern. This would check every hole's position in relation to -E- and -C-
The second portion of the FCF is what is confusing us here, with the tolerance the same as the upper portion, is there really anything additional to inspect?
If anyone has any insight as to what this means, or how to best inspect it (we've been using a CMM, but I don't think it takes the second part of the FCF into account). Does the second component yeild a 'bonus tolerance'?
Thanks in advance
[TP|0.0157|E|C]
[ |0.0157]
Thanks in advance
