Recently I encountered a drawing that I thought had an unusual callout on it. The feature control frame was for a threaded hole. The upper portion indicated a diametric positional tol of .015 dia with a projection of .750 relative to A, B, C (normal). The block directly below, attached, indicated a perpendicularity of .005 dia projected .750 relative to A.
Is this acceptable or justified by the Standard Y14.5?
Any known similar examples?
