Compressed air installation
7mayda
Petroleum
Feb 2, 2016
15
Dear,
Can someone helps me to find/tell me where is the right procedure for the materiel selection in the ASME BPVC Section VIII of a compressed air receiver 400 litres/40 bar.
7mayda, selection of materials for a given process is not within the scope of Sec VIII. Air receivers are commonly made of carbon steel, though.
Mike
Dear,
Can you tell me what is the procedure of materials selection ?
7mayda, I don't have expertise in the subject, but usually from consideration of the process, desired life of the equipment, experience with similar services, and so on.
Mike
See UG-16 (b)(4) the minimum thickness of shells and heads used in compressed air service, steam service, and water service,
made from materials listed in Table UCS-23, shall be 3/32 in. (2.5 mm) exclusive of any corrosion allowance.
r6155
Forged 3000 lb. For ngs and schedule 80 seamless pipe. Forged 2000 lbs. Valves made it of steel. Valves made in the usa by Contract or Sharpe valves. Threaded or flanged.
