My problem is going as follow: an existing equipment is supplied with compressed air through a 24ft long flexible hose with an I.D. of 0.31". 20 SCFM at a minimum of 15 PSIG is currently required. Now, a modification to this equipment will increase the flow requirement to 28 SCFM. I want to calculate what will be the pressure drop through the flexible hose with the new increased flow, in order to establish if my shop air at 90 PSIG will still supply the minimum of 15 PSIG at the equipment inlet, or if I may have to increase the flexible hose diameter.
Since the flow is quite high in regard to the hose I.D., I get relatively high velocity, which means the pressure drop is not negligeable (certainly over 20 PSIG). So, how should I evaluate the actual flow velocity along the hose, in order to calculate the pressure drop, knowing that the actual CFM (not the standard CFM) will vary along the hose because of the pressure drop? Is it an iterative calculation? Or integration?
Looking at the web, I found a few online calculators to evaluate the pressure drop in a compressed air line. However, they all give me significantly different results!
Thanks for your help!
Jean-Pierre Faucher, ing.
