I am in the process of assembling the following engine for my 68 camaro and would like to know my compression limit with alcohol.
I want to run About 50 GPH of straight meth at the peak. I have a chip burner and a wide band O2 and will zero out the power enrichment on the chip and be putting a 10% rich (lamba) curve of extra fuel using methanol under load (0 - 15" vacum). At cruise speeds there will be no alcohol injection (high vacum).
I will only be running regular unleaded (87 octane) fuel.
This is a every day street driven car. I am trying to build a high efecency motor.
The combo is,,,,
1987 5.7 Tuned Port Injection
Flat top pistons
50 cc Rhs IRON heads
Stock Roller Cam 204 /208 @.05" .430" / .460" (including the 1.6 rockers)
.035 Quench distance
I am getting down to putting the heads on.
With all my chamber and piston polishing done, I will have a measured 12 to 1 static compresion ratio.
If I take my heads into work and surface grind the heads .060"
I can have up to 14 to 1, or anything between.
Do you think 12 to 1 should be my limit, or for a little work and no extra money should I go up in compression.
The combo is,,,,
Flat top pistons
