Concentricity vs. wall thickness
ME2QE
8
Hello All,
I have a small cylindrical part that has a hole drilled into it. I am trying to decide if the OD and the ID (really the diameter of the hole) should be called out as a wall thickness or a concentricity tolerance.
The part is molded out of plastic. I'm leaning towards wall thickness because the fixturing to measure it would be much easier to make.
Thanks for any help in advance!
As the designer, only YOU know what is important for the functionality of the part.
Your dimensioning and tolerance scheme should be based on functionality, not ease of making inspection fixtures.
For minimum wall thickness vs. hole size, true position w/ LMC works well.
Mint is right but just to try and help.
At least with ASME concentricity is rarely the right control except for things like long prop shafts etc. Consider if Position or one of the runouts is appropriate based on function.
Position may allow even easier gauging, especially if you can use MMC on both the hole & OD datum feature.
KENAT, probably the least qualified checker you'll ever meet...
Doh, Tick is right, if you're really concerned about wall thickness looking at LMC may be an idea.
TheTick is correct that the hole could be shown with a positional tolerance at LMC rather than MMC to control the minimum wall thickness.
I would suggest that you reflect the hole in either circular or total runout using the OD as the datum. This will control the wall thickness a little bit easier than positonal.
Both will achieve the same results.
Dave D.
Thanks for the help guys!
You could use position @ LMC to control minimum wall thickness if that is your intent, otherwise total runout is a popular alternative, but my preference is surface profile ... you check the size & location of the surface all in one setup instead of 3 (Full-form check @ MMC, 2-pt check at LMC and then finding the actual center for position, or doing a runout check). You cannot, however, use concentricity ... it involves the Derived Median Line, and that's not a place you ever want to go ... it's beyond hard to check, and concentricity doesn't mean what it did in high school. In high school, concentricity means that the two surfaces remain equidistant from each other, under Y14.5, it means that you compare the location of the derived median line (not the feature axis) to the datum axis at each section along the length of the workpiece. That's a significant difference.
Jim Sykes, P.Eng, GDTP-S
Profile Services TecEase, Inc.
ME2QE,
Go ahead and use wall thickness if you want! If the part is not rigid then its form may vary to some degree. Using the controls for position, profile, or runout will penalize that deformed part even if it has acceptable wall thickness. As others have said "consider the function in specifying the control".
Concentricity is definately not what you want because concentricity does not control size or form... only location. For instance... the OD and ID could be perfectly straight and perfectly concentric yet have elliptical shapes where the max ID and min OD are 90 degrees "out of phase" naturally wall thickness would exhibit the extremes resulting from size for each.
If there was a wall thickness requirement one of the sizes would not be required.
Paul
ctopher,
Maybe I shouldn't be answering your question... forgive me but for rigid parts I would Yes! However for ME2QE's original question... with a plastic part and his leaning to specify "wall thickness" and his assertion that gaging would be easier... I would say it doesn't explain the size and "wall thickness" option.
Paul
Paul, the OP doesn't state if the part is (relatively) rigid or flexible. I've had molded plastic parts that weren't really what I'd call flexible.
He also talks about a hole being drilled, which would suggest reasonably stiff/rigid part, unless they just mean a hole co-axial to the OD, not specifically created by drilling.
Kenat,
Sorry if I wasn't clear. The plastic part is molded with the hold in it. Its a pretty compliant part (soft plastic).
The hole mates to a shaft. At its smallest, the hole is already .001 larger than the OD of the shaft.
I'm not designing the part, just trying to fix the drawing so that we keep a specific wall thickness intact.
I haven't used GD&T in a while so I'm taking a long time to understand what you are all saying. Anyone know where I can get a refresher of sorts? I'd even take a class all over again if I could.
ME2QE, there are public seminars around N.America. Tec-Ease is a popular source (& I just happen to be a trainer there ... coincidence...). There are other instructors who contribute to this site also (see Dingy2 above for example), so they will hopefully also provide their sites for your reference. Public sessions are scattered around, so there should be something relatively near to you. Sessions usually range from 1 day (VERY quick review course) to 3 days (lots of Q&A), and a couple of providers now offer Webinars as well. Maybe I'll meet you at a seminar. Good luck.
Hi guys, Here is my two cents: Just dimension from the edge of the hole to the edge of the outside diameter and state the minimum edge dimension. Now inspection measures the two sizes and the minimum edge distance.
dingy2,
you mention to hold the OD as a datum for a runout tolerance on the ID. Is it the same if i hold the ID as the datum and runout the OD?
ME2QE:
The results would be the same but I caution that both total and circular runout are appropriately applied on small cylindrical parts. Your part is cylindrical so it would work.
Sometimes it is easier to have the ID as the datum (place in chuck)and perform the runout on the OD. That is from a measuring perspective.
Dave D.
